Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Answer Day: Shared Storage & Working in Progress
1 REPLY 1
EKey
247 Views, 1 Reply
We, as Mechanical consultant company, are not happy with the workflow sitting behind the A360 idea: all the teams work in the same Shared Storage. We see it in a slightly different way: it is hard to chase hourly changes in other consultants' models. Also we don't like as a designer synchonize a model and an "incorrect" design appears for all consultants. We would like to "publish" our design after it was approved by a project manager.
I found that the UK standard PAS1192-2:2013 expresses the vision as ours (see the attached picture). It should be a "Working in Progress" storage, from which models can be published to the Shared Storage. We like that idea. What do you think about it?
Thank you,
Evgeny Kurbatov.
1 REPLY 1
Shawn_Niles
in reply to: EKey
I wanted to share with you the link to the Revit IdeaStation. This is a great spot to submit ideas/suggestions/concerns like you have mentioned. I've attached the link below:
www.autodesk.com/revitideas
If you have a few minutes, please go here and express your thoughts as the Revit development team will then be able to see them.
Shawn Niles
