Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
A360 TEAM shared parmaneter file
1 REPLY 1
capobianco.sergio
250 Views, 1 Reply
I'm training to set up for my company.
It's working good, but I have a problem.
Is possible to link the shared parameter file (.txt) in the project from cloud? It's possible to link the material library too?
Sergio Capobianco
1 REPLY 1
dzanta
in reply to: capobianco.sergio
Yes you can.  The way to do this is as follows:
1. Install Autodesk Desktop Connector by downloading it via this link...
https://vignettes.autodeskplm360.net/vignettes/CDXToast/CDXToast.html
2. Once installed, you will have access to your Hub Projects via Windows Explorer
3. Create the shared parameter text file for Revit within this location as well as your custom library file
4. Open a C4R project from Revit and go to Manage then Shared Parameters and tell Revit to use the shared parameter from the Hub
5. Open Materials dialog box and look and the lower left corner to see your custom library content.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
