Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
A360 and Revit 2018
3 REPLIES 3
fpensa
1115 Views, 3 Replies
A360 and Revit 2018
I have a similar issue to this one but it's not quite the same.
Since I've upgraded to Revit 2018, I'm no longer able to see all my projects in A360 as I was in Revit 2017. Funny thing is that I'm only able to see one.
So, here what I see from Revit
And here how my A360 actually looks like
All these projects are shared and includes Revit central files, managed through R4C.
I understand that I shouldn't be able to open a 2017 files in Revit 2018, but not even being able to see the directory? Except for one random?
3 REPLIES 3
DarrenP
in reply to: fpensa
did you go through this process: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
DarrenP
fpensa
in reply to: DarrenP
Not yet, but as I explained my problem is that I don't even see all the directory projects except for a random one.. I would expect to see the directories empties at least...
AdamPeter
in reply to: fpensa
BIM 360 Team projects are Revit Version specific, meaning if you have a project in Revit 2017 you won't be able to see it from Revit 2018.  Likewise Revit 2017 will not see 2018 projects either.  The first model in using C4R is what dictates the Revit version for the project.
The admin project likely does not have any C4R models in it yet and is still "open" to any version.  You can also upgrade projects using this method.
thanks,
Adam Peter
Customer Program Manager
