Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
A 360 Collaboration for Revit
16 REPLIES 16
Message 1 of 17
Chowell
849 Views, 16 Replies
Hi Community,
I am having issues when I try to upload my project to the cloud using A360 Collaboration for Revit.  When in Revit, I select the Collaborate tab, and then click on Collaborate.  I then select Collaborate using A360 and after having chosen the project I previously set up on A360 Team it takes me to this screen and gets stuck:
It will sit here for 45 minutes and nothing will happen.  Please help!!
C
16 REPLIES 16
Message 2 of 17
KyleB_Autodesk
in reply to: Chowell
This would typically happen if your instance of Revit is having trouble communicating with the C4R service.  Can you attach your Jorunal file for a Revit session that hangs during the model onboarding command?  That will tell us what part is failing.
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
Message 3 of 17
ukdxb012
I've experienced similar issues like this however id missed an update release in the very early days of C4R and communicator update. http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revit...
Kyle however is right, any issues like this and you should always upload your journal file for review.
Do you have the latest versions installed?
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-a360-...
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 4 of 17
Chowell
in reply to: ukdxb012
Attached is the Journal file.
Also, I have update release 7 installed.
Thanks for the quick replies! I still need help!
Message 5 of 17
KyleB_Autodesk
That is unfortunately an incomplete journal.  It cuts out right at the start of the model onboarding process.  If the onboarding process "hangs" after 5 minutes or so, hit Alt-F4 and that should close the window -> Close Revit -> Grab and post the journal.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 6 of 17
Chowell
in reply to: KyleB_Autodesk
how's this?
Message 7 of 17
Chowell
or this?
Message 8 of 17
KyleB_Autodesk
Close. I don't see the application close event. I do see some errors in there, but I'd feel a lot more confident if it was a complete journal.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 9 of 17
Chowell
I am unable to close the application, I have to force quit because the collaboration dialogue box remains open and I can't click anywhere.
I do use the ctrl + F4 command, but that only takes out of the project.  the collaboration dialogue box remains and I can't click on anything.
Message 10 of 17
KyleB_Autodesk
Set the Collaborate dialog to the focus of the OS (click on title bar) -> alt+F4 should close it.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 11 of 17
Chowell
Didn't work. ctrl + 4 does not close the collaborate dialogue box.  Here is another journal file.
Message 12 of 17
Chowell
So Sorry!! Alt + F4 did work! here is the log...
Message 13 of 17
KyleB_Autodesk
That's the ticket!  I see the failure, but I do not immediately recognize the error.  I will have to pass along to the brain trust to get some more insight.  What I can say is that this does not appear to be a connectivity issue, but an issue likely associated with an install.
While the brain trust takes a look, can you confirm that you have installed C4R 2015.4 + Revit 2015 UR7 on your machine?
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 14 of 17
Chowell
Yes I can confirm that I have C4R 2015.4 + Revit 2015 UR7 installed. I
tried downloading and installing them and the installation set up said they
were already installed on this computer.
Tell the brain trust thank you!
[image: suttonsuzukiarchitects.com]
Message 15 of 17
Chris.Aquino
We have seen this behavior if you are trying to initiate workshaing in C4R in a 3d view. In the journal it looks like you are in "3D View: Master Chimney". Please try initiating worksharing in C4R from a non-3d view to see if the behavior changes.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
Message 16 of 17
KyleB_Autodesk
We have a known issue where model onboarding fails if a 3D perspective view is open during the process.  Can you confirm that you have a another View type open when trying to onboard the model?
-Kyle
(edit) Chris beat nme to it!
Kyle Bernhardt
Director
Autodesk, Inc.
Message 17 of 17
allan.partridge
Have you audited your file and purged before publishing as a A360 file?  Do you have any links that need updating as well?
