synchronizing tube connections with sandwich plates from Advance Steel to Revit
Hi
Mi name is Felipe and I am working in a project where I need synchronize a steel connection from advance steel to Revit (both 2019 version). The steel connection is of type tube connections with sandwich plates additional objects. I use a base plate for connect the the column and bracing (rectangular profile). The problem is the following. When I synchronize the steel connection from AS to Revit, in the latter only appears the gusset and plates but not the bolts. I have not achieved the reason of this problem. Somebody could help me please?
Thank you!
Alfredo_Medina
Please post your question in the English-speaking forums, either the Advance Steel forum at https://forums.autodesk.com/t5/advance-steel/ct-p/4020  or the Revit Architecture forum at https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133
ok!!
