No me aparece la opción de elegir el Scope Box en Revit Architecture
Hola,un placer,tenía una duda sobre un archivo que me enviaron en el cual cuando paso a una vista 3d en la paleta de propiedades no me da la opción de elegir el scope box.Adjunto imagen ... si alguien pudiese ayudar se los agradecería mucho...Saludos!!!!
@Anonymous para una mayor claridad  @joaquim.moral ha editado el título original: scope boxes
Recuerda consultar cómo escoger el mejor título para tu post. ¡Gracias por participar!
Replies (9)
Alfredo_Medina
Scope boxes for 3d views were added in recent versions. Most it´s not available in the Revit version that you are using.
Para preguntas en español, favor usar este foro:  https://forums.autodesk.com/t5/revit-navisworks-bim-360-espanol/bd-p/317
Are those green, dashed lines Scope Boxes? If so -and assuming you are using a Version before Scope Boxes - how did you open a Version of Revit with Scope Boxes?  Revit is not backward compatible.
Alfredo_Medina
Scope boxes have been in many previous versions. What is relatively new is the ability to apply a scope box to a 3d view. The user is asking why he cannot select a scope box from the properties of the view.
Which Revit version?
Did Scope Boxes even show up in 3D view before?  I can't remember.
So, the working theory here is that the OP is viewing a Revit File that was created in a prior version - one that did not have 3D Scope Boxes?  So, I guess those aren't 3D Scope Boxes in the OPs screenshot.
I can assign a scope box to a 3d view in Revit 2019.  Not sure about older ones.   OP's properties palette does not look like Revit 2019's.
Alfredo_Medina
No, no. All versions of Revit that have scope boxes can display scope boxes in 3d views. But only beginning from Revit 2019, users can apply/assign a scope box to a 3d view.
Juanfranciscoangel
Buenas @Anonymous, de no tener la posibilidad por la versión de aplicar la caja de referencia.
Podrías seleccionar la caja de referencia y aplicar (BX).
Te animo a que siempre que publiques indiques en la versión que estas trabajando, así sabemos que opciones tienes disponible.
Juan Francisco Angel
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Luego haga clic en el botón ACEPTAR SOLUCIÓN.
joaquim.moral
Hola @Anonymous ,
¡Gracias por participar en la Comunidad Autodesk y te doy la bienvenida a los Foros en Español! Te recomiendo que para publicar en castellano y encontrar respuestas en este idioma, te dirijas directamente a nuestros foros.
Por lo que veo, has recibido varias respuestas por parte de la Comunidad.
Te ha ayudado la respuesta de @Juanfranciscoangel@Alfredo_Medina@ToanDN o de @barthbradley a solucionar tu duda?
Si es así, puedes hacer clic en el botón "Aceptar como solución". De esta manera ayudas a que otras personas usuarias puedan acceder y encontrar más fácilmente la información.
De lo contrario, coméntanos en este mismo hilo para que la comunidad pueda seguir ayudándote.
Gracias y esperamos tu respuesta,
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Your question got successfully answered? Then just click on the 'Mark as solution'
Joaquim Moral
Spanish Community
