unable to dimension walls that meet at angles
hi guys,
im relativly new to revit 2016 but have spent at least an hr trying to solve this seemingly basic problem.
i cannot mannage to annotate / dimension the angled wall or the adjoining walls.
any help appreciated
cheers
ennujozlagam
hello, you may check it here some explantions. thanks
Click HERE
RDAOU
@Anonymous
When using aligned dimensions you need to hover the mouse/cursor over the end of the angled wall then use the tab key to cycle through the extents. Once you get the small blueinsh dot (end point) left click to select it. (do the same at the other end.) - See screencast below
italonge
@RDAOU
Thank you so much! This was the best way I've found to do it. The other way is terrible, it's something like "unconnect other walls from the angled wall, than select it and click in the temporary annotation, then Revit will create the permanent annotation. So, you have to connect walls again"
Why so difficult?
What is difficult?
