the pictures shows two instances when i zoom in and zoom out.the wall column joint is cut out when i zoom out . What can be the solution herezoomed out
zoomed in
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
They appear not joined
Use Join Geometry and pick Column then Wall (You can use also switch Join Order to reverse the join)
