I have an issue, such when I use zoom extents command in a 3D view, the view zooms way out of the actual model. I have managed to pinpoint that this issue occurs only when I have the casework model category visible in visibility/graphics overrides (even when all the subcategories of casework category are deselected). I have been importing families into this category using Rhino.Inside.Revit plugin pipeline. But even though I deleted all such families and purged the whole model, the problem persisted.
Any idea how to fix this issue?
Any suggestion would be much appreciated. Thanks.
Revit 2022.1 v. 22.1.40.58
Rhino.Inside.Revit v. 1.12.8449.6358
Rhino 7 SR34 v. 7.34.23267
thanks for the suggestion. I will do that.
Hopefully I will not get redirected back here, since it is kind of borderline issue.
@mpapez wrote:Hi,
It's called "passing the buck", I think.
If you could provide more detail on what they're specifically suggesting you do in Revit, that would help me to help you.
