Zone definition - Axe
nrmsdl
nrmsdl
Hello. Is there any way to control the size of the axe from the zone. Please see the jpeg. Thank you
nrmsdl
To precise the question, this is when the scope box is applied to the axe
Sahay_R
Are the grids associated to the scope box? The bubbles will then jump to a predetermined distance from the scope box. This is a value stored at the system level with no user control. I do not know the exact value. To change - delete the scope box, create a new one of the desired size, re-associate.
Other alternatives - drag the bubble out. If they are locked to each other, then you will be able to drag them to the desired distance consistently. Setting up a reference plane at that distance would also be helpful.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
nrmsdl
Reference plane! Thanks
