Zero threshold
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Debfar
136 Aufrufe, 2 Antworten
Zero threshold
Hi, community,
how to achieve a zero threshold?
I have a sliding patio door that divides the exterior and interior and the door track needs to be flush with both floors. How to do that? Does anyone have a sliding door family with this integrated threshold? Thank you
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Debfar
- Edit the door family, remove the cut opening and replace it with a void to cut the host wall.
- Model the track in the same family below the door then add another void the same volume as the track.
- Uncut geometry or set the void to Not Cut geometry so that it does not cut the track.
- Set the family to Cut with Void and Loaded.
- Load the family in the project, it will cut the wall automatically.
- Use Cut geometry to further cut the floor with the door family then you will have a flush track embed in the floor.
Nachricht 3 von 3
Debfar
als Antwort auf: ToanDN
Thank you! that worked! I still don't have the right door system track, but this solution is great! thanks
