Question best asked in video form. File attached.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
See attached. It is better to use reference lines to draw the path with dimensional parameters, then draw the sweep using Pick Path.
You can also draw the sweep (as in-place model, railing, fascia, gutter, slab edge, wall sweep) directly in project for maximum flexibility: straight path, L path, Z path, /\/\/\ path, curved path, etc... Don't limit yourself to using a family for each shape.
Thanks, this is for a fabrication shop. I am making all of the standard shapes parametric families so make drawings is much faster.
