Your model needs to be upgraded from Autodesk Revit 2009 or Earlier.
3 ANTWORTEN 3
Nachricht 1 von 4
399 Aufrufe, 3 Antworten
I am receiving the following error when opening a Revit 2019 file with Revit 2019.2 "Your model needs to be upgraded from Autodesk Revit 2009 or Earlier to Autodesk Revit 2018. When you cancel Revit Closes, When you open Revit again it cant connect to the license server anymore. neither can any out version of Revit and other Autodesk applications.
I have rebuilt the PC 3 times and the same issue happens where the system is able to connect and get a license from the server then top after a while. All other PC on the network are working fine just this PC.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Faulty wired connection? Have you installed the latest licensing updates? Are there any odd add-ins or processes running on your machine?
Nachricht 3 von 4
All updates applied, we have no plugins installed. I have move the pc to another network point and have tried wireless also. Disable antivirus and Firewall and still fails to connect.
Nachricht 4 von 4
RobDraw
The cause could be from a family in the project. Not sure how to fix it. Just trying to point you towards a solution.
Rob
