Announcements
Your Model is Being Upgraded from Autodesk Revit 2017 to Autodesk Revit 2018
kareltriarc
kareltriarc
Is it normal to get this error message when opening a template in Revit 2018?  We never used 2017.
Replies (11)
DarrenP
this is not an error message
the template you are trying to use was created in 2017
was this a custom template or an out of the box template?
DarrenP
kareltriarc
It's just an out of the box template opened from C:\ProgramData\Autodesk\RVT 2018
kareltriarc
I didn't mean to refer to it as an error message.
RobDraw
You said you never used 2017 but was it ever installed on that machine?
Is that the actual OOTB template you are opening or is it a project set up with that template?
I have to make sure we are absolutely clear on this as a number of people use the word template when they are actually talking about a project.
Rob
Tony_Michniewicz
We've heard sporadic reports of instances where the wrong version of Revit content is installed.  Initially, we thought this might be related to left over files in the Windows temp folder but after lots of testing, we were not able to reproduce this issue.  We continue to monitor this issue in hopes of identifying the underlying issue.
In regards to your existing content issue, I would recommend the following:
  1. Use the Windows Control Panel to uninstall Revit Content Libraries 2018.
  2. Delete any files that remain in the following folders:
    C:\ProgramData\Autodesk\RVT 2018\ContentPacks
    C:\ProgramData\Autodesk\RVT 2018\Family Templates
    C:\ProgramData\Autodesk\RVT 2018\IES
    C:\ProgramData\Autodesk\RVT 2018\Libraries
    C:\ProgramData\Autodesk\RVT 2018\Templates
  3. Delete any files that remain in the Windows temp folder.
  4. Reinstall the Revit Content Libraries 2018.
Another suggestion would be to use the DLM version of the Revit installer instead of the web installer.  The DLM version contains the necessary content files as part of the install media and this eliminates the need to download the content.
Tony Michniewicz
Revit Software QA Analyst
kareltriarc
Hello and thank you for your help.
2017 was never on the computer.  I am opening up an actual OOTB template.
I first downloaded and created the deployment on 4/25/17.  After install, we got the error that “The path you have specified for the default family template is invalid.”  The folders for the templates were empty even though Autodesk Revit Content Libraries 2018 was in the Windows installed program list.
I found a fix here:
http://blog.manageddesign.com/missing-revit-content-libraries
I noticed that those files mentioned were missing from my deployment so I got them from a new download.  I uninstalled Autodesk Revit Content Libraries 2018 and ran the deployment again.  Everything looked to be working correctly except for this “model is being upgraded” message.
Do you still think the removal and rerun of the deployment being a fix because it was just done?  I found this of course but it never mentions deployments:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
chrisplyler
I have had this problem since I installed 2018. If I start with one of the standard templates, they begin with - and have to update every time - the 2017 template files. And yes, I've checked the path options, and they do point to the 2018 folder. The files in the 2018 folder are 2017 files.
I've just lived with it.
martinTstewart_Adsk
Autodesk Support
Autodesk Support
In addition to Tony’s helpful response above -- if it’s just the templates -- it would be a quick fix to open each of those templates directly in Revit 2018 and Save As.
So the steps would be:
  1. In Revit 2018, open first template
  2. Do a Save As and append the name with a single number or letter, since it won’t let you overwrite the file. For example: default1.rte or defaultZ.rte.
  3. Close that template, rinse and repeat (Do this for each template).
  4. Then in Windows File explorer, delete or archive the original templates
  5. Rename the templates you just saved back to the original name by removing the appended number or letter.
  6. Now all your default templates are in Revit 2018 format and you should no longer experience the upgrading you mentioned.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).  Smiley Happy
Martin Stewart
AEC Support Specialist
chrisplyler
Sure. I've had that idea but just haven't gotten around to it. But it isn't just the templates, it's the entire family libraries as well.
martinTstewart_Adsk
Autodesk Support
Autodesk Support
Tony's response would fix that, though I'd download a new, fresh Revit download from your Autodesk Account, using "Download Now" rather than "Install Now".
Martin Stewart
kareltriarc
I have downloaded the program from my Autodesk account again already.  After, I followed the instructions in the link below get the missing extracted files from the C drive to the deployment folder (where they were missing).
When I browse C:\ProgramData\Autodesk\RVT 2018\Family Templates\English_I I notice that all of the rft files are dated 1/22/16.  Any way to get the updated versions?
Type a product name
