Is it possible to write a formula for a yes no parameter that is only visible between 2 set lengths?
I want 1 item visible if the length is less than 2', 1 item visible if the length is over 3', and one item that is visible between 2'-3'.
Is it possible to write a yes/no formula for this option? if not what would a work around look like?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
-_-..... SHHHHHH.....
the answer wasnt supposed to be that simple....*bangs head on wall* cant believe i missed that.
Thanks ToanD
