Yes/No parameter to turn off other Yes/No parameters
Jeremy.Van.Ryswyk
Message 1 of 10
Jeremy.Van.Ryswyk
Hi, is it possible that when Showtext is off, all the graphical parameters will turn off. But still keep the graphical parameter's to the type?
Replies (9)
Message 2 of 10
Alfredo_Medina
No. Seems that what you are doing would be more efficient using a family type parameter that contains different notes, one for each discipline. In that case you would need 2 parameters only, one that handles visibility and another one (family type) that handles the graphics or notes.
Message 3 of 10
Jeremy.Van.Ryswyk
Not sure this still gives me the result I want. I've nested the family which gives the instance control visibility. But the type visibility is still an issue. Going to see what we can do with listing to resolve that
Message 4 of 10
juliar123
I would try using an If formula.
Reminder: For yes/no parameters :
Yes = True = 1>0
No = False = 0>0
The formula I used is below:
if(Show Text, (1 > 0), 0 > 0)
Because you have different types with only one thing checked on per type, Put this formula in for the one visible element in each Type, then if you check off Show Text, it will remove that text.
This is a fast example of what I did below:
Message 5 of 10
Alfredo_Medina
It is not necessary to use 1 > 0 nor 0 > 0 in formulas for yes/no parameters.
All this:
if (Show Text, (1 < 0), 0 > 0)
can be replaced with:
Show Text
So, the value of Mechanical Text is always equal to Show Text.
Message 6 of 10
juliar123
You are correct! I'm getting too far down the rabbit hole Haha.
Message 7 of 10
Jeremy.Van.Ryswyk
Smart guy at work worked it out. Nested each consultant mark up tag into the family. Then used them as a instance family list. Then had some intermidiate parameters to another formula to switch them off in the instance based resolved and switch the whole lot off globably as a type parameter
Message 8 of 10
Alfredo_Medina
See message # 2 above.
Message 9 of 10
Jeremy.Van.Ryswyk
What about it? I think what your saying wouldnt shedule right with the instance mark up comment
Message 10 of 10
mattVW6PK
You have to set up a second parameter for each instance.
Example:
Mechanical (parameter under Visibility) with Formula = and(Show Text, Show Mechanical)
You will need to change any instance using the current Show Mechanical to the new Mechanical
