yes/no parameter formula
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
KieranWood
554 Aufrufe, 6 Antworten
Can anyone assist with a formula which completes this
if I select "a", "b" & "'c" will hide,
if I select "b", "a" & "c" will hide,
if I select "c", "b" & "a" will hide.
6 ANTWORTEN 6
Nachricht 2 von 7
ralphdenhaan
als Antwort auf: KieranWood
Use the example below for that:
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 7
htews
als Antwort auf: ralphdenhaan
i've tried this but it keeps saying "the following is not a valid parameter: LDR_Center'
Nachricht 4 von 7
mhiserZFHXS
als Antwort auf: htews
Look back at the screenshot more closely. You need six parameters.
Also, you have a parenthesis at the end of your parameter name, which is why its not being recognized.
Nachricht 5 von 7
htews
als Antwort auf: mhiserZFHXS
this is what i have to show either left visible or right visible
i figured if I added a line called LDR_Center that simply add the formulas in but that doesn't seem work.
Nachricht 6 von 7
For more than 2 conditions, it's better to use an Integer parameter instead of a Y/N parameter to drive the conditions.
Nachricht 7 von 7
htews
I came back to this detail....
i am trying to get this work....independently, I'm trying to get this visibility to work left or right.  I got the linework to show up 1, 2, or 3 but i need to get left showing, right showing, both on or both off.
