Yes/No Parameter - Detail Items
7 ANTWORTEN 7
Nachricht 1 von 8
mrheuseler
862 Aufrufe, 7 Antworten
Do any of you know WHY THE H... it's so difficult for Autodesk, to create a possibility to add a Yes/No paramter for text, when creating Details-families? :leicht_lächelndes_Gesicht:
(Please see picture!)
Or is it just me?
I need a way to turn of the text, so I get a clean drawing.
Thank you very much.
Kind regards.
7 ANTWORTEN 7
Nachricht 2 von 8
Ilic.Andrej
als Antwort auf: mrheuseler
Simply select the text note, right click: Hide in View/ Elements
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 8
mrheuseler
als Antwort auf: Ilic.Andrej
Have tried that, but the Hide in View-option is not available in the Family, when I right click.
Another issue now is when I try to Load the Detail-family into my project, the text disappear. (Picture attac.)
Only sollution I can spot is to import AutoCad-text into the Detail-family and suddenly it works perfectly.
Think is a bit waste of time thougt.....
Nachricht 4 von 8
Ilic.Andrej
Create generic annotation family and then nest that annotation family into the Detail item.
Andrej Ilić
MSc Arch
Nachricht 5 von 8
Ilic.Andrej
Andrej Ilić
MSc Arch
Nachricht 6 von 8
Corsten.Au
Hi
1. If you dont need the text, one way is to simply delete it... ( keep a PDF for reference  )
2. Second option is to create a new " Text Style " with White colour.. so it will stay there but
not visible..
Best luck.
Corsten
Building Designer
Nachricht 7 von 8
mrheuseler
This is the best solution so fare!
Thank you very much. :leicht_lächelndes_Gesicht:
Nachricht 8 von 8
Ilic.Andrej
You re very welcome
Andrej Ilić
MSc Arch
