yes/no in IF statement
3 ANTWORTEN 3
Nachricht 1 von 4
htews
355 Aufrufe, 3 Antworten
need a little help.  I have an operable wall that I can show the wall open or closed.  where I am having trouble is I'm trying to show 2 passage doors in different positions along the wall.  trying to figure out the formula so that if the panel_vis is on, I have the options to turn door1 on or off as well as door2, but obviously when the panel_vis is off, both doors are off.
any ideas?
thank you.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: htews
PassageDoorVis1=if(Panel_Vis, Not(PassageDoorVis2),PassageDoorVis2)
where Panel_Vis is assigned to visibility parameter for PassageDoorVis2
Nachricht 3 von 4
als Antwort auf: barthbradley
should read: "where Panel_Vis is assigned to visibility parameter for Passage Door 2"
Nachricht 4 von 4
htews
barthbradley,
not was i was looking for BUT this is how I got it to work.
added 2 extra parameters.
