xray like symbolic lines
10 ANTWORTEN 10
Nachricht 1 von 11
nathaniel.mcmahon
549 Aufrufe, 10 Antworten
Any ideas what could me making the symbolic lines in a furniture family appear through walls in rooms far away from them like the example? They're place on a reference plane that determines the front of the furniture. the cupboard isn't even near the wall they are seen through.
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: nathaniel.mcmahon
Are those lines not in your family?  Check in the family editor that the reference lines and planes are set to show in the view - they may be hidden.
Nachricht 3 von 11
bin
als Antwort auf: Anonymous
Those are Symbolic lines in the family, which are supposed to be hidden in that view ( the families are behind the wall). I had the same issue sometimes but was too lazy to fix it. I just hide the family or Linework them.  I’ll wait for the answer.
Nachricht 4 von 11
ennujozlagam
Edit your family and check your visibilty setting uncheck elevation and section and see if helps. Thanks
Nachricht 5 von 11
nathaniel.mcmahon
Those lines are in the family and are set correctly.
The problem isn't that they are not showing but that they are showing
through all things between the family and the view. I have external
elevations with cupboard swings showing through.
Nachricht 6 von 11
Does this happen in multiple views or just the one view?
Nachricht 7 von 11
nathaniel.mcmahon
Multiple
Nachricht 8 von 11
My guess is that you have a Model Line in Plan View of the Family and the View's Cut Plane is intersecting with that Model Line in the Project.
Nachricht 9 von 11
Do you have any floor clearance built in the family that may intersect the elevation far clip extent?
Nachricht 10 von 11
bin
Maybe it’s something about the Show When Cut option.
Nachricht 11 von 11
Corsten.Au
You will find the settings here.You will find the settings here.
Corsten
Building Designer
