WTF Vertical Family Sweep Profile displays Horizontally - Properties also change from Sweep to Wall !
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
christopher_c_donovan
208 Aufrufe, 2 Antworten
Using a Wall Hosted Profile [Sub Category Profile] for a SWEEP but 1] it is displaying/ coming in on the Horizontal Plane and 2] Its Properties have changed from a SWEEP to a WALL. This has consequences [obviously?] when editing/modifying it. ie the Modify Ribbon no longer displays the far right Option WALL SWEEPS so that you can taken advantage of : ADD/REMOVE WALLS or MODIY RETURNS.
I attach the Family file: SHATIN PLINTH - The Project File TOWN PARK -2 and a double check Project TEST which i carried out to a] keep it simple and make sure I had not accidentally changed the Work Plane which given the way the Family behaves [in the Horizontal Plane] would be the most obvious explanation of how I got here!  If it is what is happening then how did I get here?   In Town Park Project created a Reference line and a Work Plane call West End Wall [or similar]  in Test selected the Face of the Wall as you should be able to see.
2 ANTWORTEN 2
Nachricht 2 von 3
Mike.FORM
als Antwort auf: christopher_c_donovan
From what I gather you want to create your sweep using the wall sweep function found under the walls dropdown. You can create a sweep type and assign the profile you want to that type.
You do not need to make this using the model in place function.
Nachricht 3 von 3
I works fine as a Wall Sweep as per @Mike.FORM's post.
The sweep also could be built into the Wall Type.  FWIW.
