Hello everybody,
I've linked an AutoCad drawing into my model. In this drawing we've used different linetypes with different text. But if you look in my Revit model, I can't see this text and also the color of these lines are red instead of grey, such as in the drawing.
(Ps. The AutoCad layer with the grey bar, isn't visible in the model because it's turned off in Revit)
Reloading the drawing doesn't help.
If I change the linetype into "continuous" and i reload the drawing, the line becomes the right color, grey, and continuous. If I change this back into the right linetype again, the line becomes red again after reloading and the text B60 is still not visible.
The AutoCad layers are all "color by layer", why becomes this line red?
Does anybody knows how I can solve this?
(I'm using AutoCad 2018 and Revit 2019)
