Wrong IFC export of slanted walls
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
Alex_Figueres
883 Aufrufe, 4 Antworten
Exporting Slanted walls to IFC results into bad geometry:
Walls modelled in Revit 21.1.1 and exported to IFC with the newest IFC exporterWalls modelled in Revit 21.1.1 and exported to IFC with the newest IFC exporter
Walls in SolibriWalls in Solibri
Is this a known issue (I din not find anythin gon the forum).
Any ideas how to fix this?
Best regards and thank you in advance!
Alex Figueres
4 ANTWORTEN 4
Nachricht 2 von 5
Alex_Figueres
als Antwort auf: Alex_Figueres
EDIT:
The IFC is correct when exported in IFC 4 Reference View. Only with this setup.
IFC4 Reference View:
Nachricht 3 von 5
tassifb
Hello, I tried using IFC4RV but it didn't work.
Maybe with some specific configuration?
Nachricht 4 von 5
Lance.Coffey
als Antwort auf: tassifb
It sounds like you are seeing the issue described in the following article: Exporting slanted walls to IFC is incorrect
If IFC4 Reference View is not working for you, check the version of the IFC exporter (make sure it is updated to the latest version).
Lance Coffey
Technical Support Specialist
Nachricht 5 von 5
Alex_Figueres
Hi There!
Precisely, @Lance.Coffey ! The article you refer came as an answer to this same question I run through Autodesk support.
The issue is currently under investigation :leicht_lächelndes_Gesicht:
I forgot to update this thread!
Hava a nice day and thanks for following up!
Alex
