Wrong floor calculation with Roombook
3 ANTWORTEN 3
Nachricht 1 von 4
403 Aufrufe, 3 Antworten
Hi, i am learning revit from the official help site, and i got this trouble when calculating floor from two rooms using roombook extension. The trouble is about the contour which roombook identifies for the floor faces, in the images below you can see that the contour didn't reach the wall face, producing less area quantity. I Can't find the manner for revit to identify the wall boundary the right way.  The ceiling calculation is right for the left room, but get the same error when calculates the room at the right.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Post your file.
Nachricht 3 von 4
als Antwort auf: barthbradley
Here it is. Please dont mind the coherence of the model, im just using it for testing things.
PD: Use the View "NV1 - Copia" And 3D Default to see the problem.
Nachricht 4 von 4
I see what you're seeing, but unfortunately, don't get it either.  Looks like vanilla Revit figured it out accurately though. Light Blue is the Room Interior Fill.
Thanks alot. This is going to gnaw on me now.  Arrgh!
