Hi There, sorry to disturb . I encountered an unspecified misunderstanding from vers.2020 which decides to relocate above the correct level my staircase dragging up the base level up for at least 100 cm. This hasn't sense for me. Any solution?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
So, 41 is the offset from the base level which I need to land my staircase: the offset which sould be from :Piano di Riferimento. Instead of this, It leaves the staircase directly at the top level which is named Piano quarto Sottotetto..why ?
Interesting. What's the Warning all about?
Let's take a look at it. Post the file.
Hi there..I posted the Warning post. Actually I placed the staircase under the base level about 100 cm underneath reaching the desired hight from my real level...For me I can arrange this doing this trick , It s very unhealthy unfortunately. Tell me the solution if you can ![]()
I will give you a concise copy of that. But Thanks for you patience.
I think you ll get around.
Lorenzo
