After cutting wall angle with "Edit profile" how can I make Wrapping for cutted part?
Like this:
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Wrap as in the built in wall wrapping at the top is not possible, but it is possible to achieve a similar in different ways
Looks like you already did. Are you wondering how to align it properly? TAB-Select the Model Pattern and use the Rotate Tool.
Yes that's what i tried to achieve.
Photo was edited to show what result I wanted, I couldn't find solution. What posted @RDAOU is solution and result what I tried to achieve.
Yeah, In photo it looks like I already achieved it, despite fact that it's quick photo edit (i guess it's good edit if it's believable :)).
&&&Thanks for help.
