wrapping separated wall
11 ANTWORTEN 11
Nachricht 1 von 12
sm.sadat89
1295 Aufrufe, 11 Antworten
Tags (2)
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: sm.sadat89
In the Family; check  "Wall Closure" for the Center Ref. Plane.
In the Project; check "Wrap" next to Wall Layer you want to wrap and move that layer out of the "Core".  Then set "Wrapping at Insert" condition.
...or, approach 2:
In the Project: check "Wrap" next to Wall Layer you want to wrap and move that layer out of the "Core".
Under the Type Properties for the Door in the Project: Change "Wall Closure" Door Properties in Project from "By Host" to another value (i.e. "Exterior").
Nachricht 3 von 12
sm.sadat89
als Antwort auf: barthbradley
thanks barthbradley
but structure wall not wrapped with finish layer...how finish layer  wrapping structure  wall too?
Nachricht 4 von 12
If you model the structural and the finishes as separate walls then you need to create a separate, wider opening for the structure to match the rough opening size. Why not keep them as a single compound wall?
Nachricht 5 von 12
@sm.sadat89 wrote:
thanks barthbradley
Yes, that how wrapping works.  Structural doesn't wrap.
Nachricht 6 von 12
sm.sadat89
als Antwort auf: ToanDN
hi...because managing of this method is easier. and the number of wall
decrease.
Nachricht 7 von 12
You can also look at the Edit Assembly dialogue - the wrapping depends on how the core layers are organised.
Nachricht 8 von 12
decrease.
It is debatable.  Easier yet you are having a hard time making them wrap.  The number of wall decrease yet in the example you have 3 walls instead 1.
Nachricht 9 von 12
sm.sadat89
for example we have wc between bedroom and living room.
we should have 3 wall for 1wc
1 wc living room wall
2wc bedroom wall
3wc exterior space
but this metod
1structure wall
2 wc finishing wall
Nachricht 10 von 12
You meant fewer wall types, nit walls, and it is true. So it is between fewer types but more elements versus more types but fewer elements. Pick yours poison.
Anyways, as already said, you need a bigger void to cut the structure wall separately from the door or window.
Nachricht 11 von 12
@sm.sadat89 wrote:
thanks barthbradley
Funny, when I first read this reply from you, I thought wanted the Structure to wrap as well -- which is a strange concept.  I see now that you were talking about making the wrap go deeper.  You cannot do this when you model your wall layers individually, but you can do this if you make compound-layered walls.  Use my second approach above with compound layered walls and you can change the depth of the wrap by changing the location of the "Wall Closure" Ref. Plane(s) in the Door and Window Families.  And, you can set it up so you can control the wrap depth through Instance Parameters, so each instance of the Door or Window Family placed in the Project can have it's own unique wrapping condition.   If you really, really need the walls layers separate from each other, then create Parts from the compound-layered walls.
Nachricht 12 von 12
I searched a lot for a solution to this problem and I can safely tell you that there is no way to wrap separate walls around inserts , the wrap works only with wall layers not independent walls,  The solution I came up with was to make a wall based family that cuts around the opening and create the desired cladding wrap as a sweep , I think Revit developers should find a solution for this as many people  are modeling wall layers separately especially in large projects as you can't afford to have a wall type for every single type of wall also when you have structure model including RC walls on a separate links , not mentioning that its easier to have separate walls for quantification and 4D models
