Is there a way to make the wrapped wall understand that the door has an object which is actually insulation to avoid cold bridge. Please see the picture below. The gray rectangle is from the door family, and I intended to have it as an empty space for insulation. Thank you!
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
For this you have to create separate wall with change in insulation thickness. for that gray portion, place the created wall and it will work. Try this
In the door Family,
When you load the above door it should cut the wall as expected
It worked with the warp wall method, to leave space in the wall. I was mostly interested in the concrete part to have a gap, not necessarily the insulation too. Thank you!
