One roof for the primary roof, another for the wrap around. Join the roofs together.
https://forums.autodesk.com/t5/revit-architecture-forum/roof-with-2-different-slopes/td-p/3339221
When you create the footprint, you can select walls and pick lines of the porch boundary. Assign the required slope to the slope defining lines. Exit edit mode and in the properties, place at the height you need. Join to existing roof.
I have a roof over the walkway to my front door and this roof is part of the roof over my garage. It almost looks like a wrap-around style roof. I would like to remove the part of the roof over the walkway to my front door but can't justify rebuilding the entire roof. Can this be done easily?Roof over front porch. Can it be removed?
