Worksharing
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
kamaluddin.shaikh9
410 Aufrufe, 4 Antworten
Worksharing
Hii
What is the difference between synchronize and reload latest ?
Bcoz when iam working on particular model, so when I make any changes and sync it to central model, so it showing another updates also which done by another user,
I didn't use the reload latest command, so why its happening ?
4 ANTWORTEN 4
Nachricht 3 von 5
Reload Latest: Downloads the latest updates from others but don't upload your updates.
Synchronise: Downloads the latest updates from others and uploads your updates.
Mostafa Elashmawy
Nachricht 4 von 5
RDAOU
als Antwort auf: kamaluddin.shaikh9
Reload latest loads updates from the central without publishing your changes to the central model. This is more like a single task operation that fetches all synced data and updates your local...this operation, on a decent network and a decent workstation takes 3-10 secs
Synchronize is a multitask operation...saves your changes to the central model, Saves a local copy, Loads all the changes since your last Reload Latest or Sync, Saves a local copy after sync, relinquish worksets and stuff ... Depending on the size of your project this could take some time to be carried out (>30 sec)
Nachricht 5 von 5
