Worksharing Monitor 2019 does not display model
5 ANTWORTEN 5
Nachricht 1 von 6
ToneStilen
922 Aufrufe, 5 Antworten
WSM for my Revit 2019.2 does not display the workshared model properly or not at all - see attachment.
It has kind of gone wors over an period but now it has stopped completly to show anything.
What to do??
5 ANTWORTEN 5
Nachricht 2 von 6
RobDraw
als Antwort auf: ToneStilen
Remove and reinstall, that might fix it.
Rob
Nachricht 3 von 6
RDAOU
- Are you having multiple Revit sessions on you PC accessing the same Central?
- Did you try to clear the Worksharing Log file (*.slog) you can find it in the central file backup folder?
Nachricht 4 von 6
ToneStilen
als Antwort auf: RDAOU
-Just one Revit session
-did clear out the *.slog-file
= no solution :enttäuschtes_Gesicht:
Nachricht 5 von 6
RDAOU
@ToneStilen
Sorry to hear that you have found no solution...I can't think of any other reason ….Is everyone using the same update/build 19.?.?.??
Nachricht 6 von 6
Solution:
This issue happens when your file name and folder Path has more than 256 characters in it. Revit has to create SLOG file that Revit worksharing Monitor access it to report. The slog file will be <FILE NAME>.slog. If you have the long file name and the path exceeding 256 characters, Revit fails to create SLOG file and hence Worksharing Monitor cannot display any data to its interface.
At this stage, Revit does not provide any warnings if it can't create a SLOG file however you will get a warning from Revit while you save RVT file that exceeds 256 Characters.
The solution is to reduce the number f character in the file name or folder Path. You can use MS Word to copy the path from Windows explorer to count the character. Below is an example to replicate the issue.
Hope this helps.
