hi
while going thru the worksharing journal (and some other files in the backup folder of a model) i noticed, that notepad++ (and other tools) identify the encoding as "UCS-2 LE BOM".
this raised a few questions for me:
1) is it really UCS-2 or is it UTF-16 being misinterpreted? because UCS-2 is deemed obsolete.
2) no matter if UCS-2 or UTF-16, why was it chosen over UTF-8?
2a) as is, files are around double the size it could be if encoded as UTF-8, which in my opinion is important as these are frequently accessed files so possibly slowing down all users involved.
2b) at least the worksharing journal seems to not contain special characters that would warrant for spending more bits on characters.
3) why is there a mix of different encoded files within that backup folder and the local journals, that is just asking for trouble, no?
the mix i've found on a windows machine:
(also, the EOL is a mix of Mac(CR),Windows(CR LF) and Unix(LF)...)
local
backup folder of the central model
I have used Notepad++ in the past, it's not on this computer so I can't double check...my recollection is the format is a user preference setting. When I open a .slog in Notepad and use Save As the format UTF-16 LE is already selected.
Steve Stafford
trying to read it with python only works as utf-16 (which is more or less ucs-2), so that is set by the file.
plus, resaving the file as utf-8 makes it roughly half the size because it wastes less bits per character, so this seems not to be a notepad++ issue. plus i tried other editors as well and they came to the same conclusion encoding-wise....
