Worksharing - Greyed out "in central"
4 ANTWORTEN 4
Nachricht 1 von 5
craig_SW
2568 Aufrufe, 4 Antworten
Dear Hivemind,
I've noticed one of the users on a Workshared project is getting a greyed out "In Central File" appearing on and off in the WS Monitor. It's not affecting their work or the model. It appears to be random.
Anyone know the why?
Thanks in advance.
4 ANTWORTEN 4
Nachricht 2 von 5
kadmonkee
als Antwort auf: craig_SW
are they opening the central file and not creating a local file?
are you using worksets that are owned by users?
are you using filters or view templates that manage worksets?
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 3 von 5
craig_SW
als Antwort auf: kadmonkee
Thanks for the reply.
No.
No.
No.
C
Nachricht 4 von 5
kadmonkee
are all your users , using the same build version of Revit, service packs patches fixes etc.
are all of your projects on a network environment?
are you using a Revit server for some projects ?
work share monitor does not work with the Revit Server - thought I would ask.
on the help button use the down arrow and select About Autodesk Revit 201X for your version.
thank you
Nachricht 5 von 5
Viveka_CD
Hi @craig_SW
Can you check the recommendations at the link HERE
Let us know if you were able to resolve this issue.
