Every time I reopen a central model project with multiple linked central revit models the Workset " shared levels and grids" which I personally closed are re-opened everytime. We double checked that the grids in the loaded models are in this workset.
What am I doing wrong ?
Regards
Gelöst! Gehe zur Lösung
Gelöst von Sujan.Maharjan. Gehe zur Lösung
While making a Central Model I personally set Default Opened Workset to Specify so that-
Psst, I assume that you Create New Local From Central Model each time you open the Model
yep !
Regards
