Worksets ownership when project switching from full licence to LT
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
NathalieKD
243 Aufrufe, 4 Antworten
I have an issue. I started working on a project with a full revit licence trial but then i had to open it in LT once the trial was over. I dont think I did any steps to relinquish everything, I just made the switch directly as I coudn't open the file anymore.
Now in LT, I cannot delete any views (but can rename them), there's an alert about the deletion of a non-modifiable workset. Similar issues with families; I created some families using LT, uploaded them into the project. Somehow, if I edit the families and try to load them again, it doesn't work and it gives the same alert message.
Anyone has a solution for this? Thanks!!
4 ANTWORTEN 4
Nachricht 2 von 5
RSomppi
als Antwort auf: NathalieKD
I have no idea how to fix this but you are trying to use a workshared project with LT which doesn't do worksharing. You need to make that file non-workshared.
Nachricht 3 von 5
I don't use LT so I can help you from that end.  But you can ask someone to with a full Revit to open the file detached and discard Worksets, save it and you can use that file in LT.
Nachricht 4 von 5
NathalieKD
als Antwort auf: ToanDN
Thank you !
Nachricht 5 von 5
RSomppi
You're welcome.
