I've never seen a workshared project that does not have the following 2 worksets:
However, on one of the projects that I'm working on Revit 2017 I can see this:
This is the same case if I open any central or local file. It isn't causing any issue as such but I found it very strange since one cannot even delete the aforementioned 2 worksets in normal files.
Gelöst! Gehe zur Lösung
Gelöst von Alfredo_Medina. Gehe zur Lösung
@virajvoditel wrote:I've never seen a workshared project that does not have the following 2 worksets:
- Shared Levels and Grids
- Workset1
Can this happen if it originated in Revit LT?
Please refer to this other similar thread: http://forums.autodesk.com/t5/revit-architecture-forum/missing-worksets/td-p/6735398
I hope it helps.
