Is there a way to reduce the number of points displayed on screen when working with point clouds in Revit?
I have large point cloud files to work with and they are causing huge lag in Revit. Is there a way to reduce the amount of points displayed, similar to the way you can in AutoCAD? In CAD I can simply move a slider to display fewer points, a level of detail slider in the point cloud tab. I can't seem to find any similar function in Revit.
I am aware that I can reduce the point cloud itself outside of Revit and then bring it in to Revit after, but this is time consuming. I am working with roughly 400 scans worth of data.
Thanks.
