Working with Client Provided Models:
We regularly get client/owner supplied models. We have been lucky that most of them have been decent enough. Normally when we get new models in, the Project BIM Lead will let me know where they are at and I will Vet them. I will run them thru the Standard Checker provided in the BIM Interoperability Tools extensions and see what it says. From there I may purge unused, and check Compress Central Model when doing a save.
Recently have received some models that were less than ideal to work with. On this project All we needed was the modeled content for existing conditions. I ran them thru the eTransmit for Revit tool. In eTransmit for Revit, All the way at the bottom, is a "Remove all Sheets Except" option. I select that and uncheck all the options in the check box(s). eTransmit removes all the View/Sheet/etc. content and purged leaving only the modeled content.
Working with CAD provided backgrounds:
We have many clients that still require CAD deliverables. We receive CAD files and choose to do the project in Revit (cause its better 😊). If the CAD files are from a sub-consultant, we can dictate to some extent how they work. If the files are from the client, we must deal with what they give us. we also frequently have sub-consultants that only uses CAD on our Revit projects (typically Interiors or Elec for some reason). In these cases, we link in the CAD files and manage the layers the best we can thru the VG Overrides > Imported categories. most things can be controlled thru View Templates.
Working with Owner provided templates:
When a new standard comes in, I take it and look thru their BIM Standards, if provided, and any accompanying templates. Recently we have had several of our clients make the move from CAD to BIM. Several have provided us with their templates. Some are great, well thought out with a good structure to them. unless their BIM Standard says I can’t, I will transfer our VT’s and Worksets into their template.
Others look ok until you get into them. In that case we have a decision to make. Talk to the client about the issues with their template or adapt our internal template to match their BIM Standard.
Howard Munsell
