Working with model from 3Ds max/AutoCad
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
shershahbacha9
297 Aufrufe, 1 Antwort
Hello !!
I have a Model from 3Ds max opened in Revit. I had a DWG which was created from 3Ds max and I imported this DWG in Revit. I exploded (Partial) in Revit and i can select each element but when i select any element, there is this box around it. How can I clear these boxes from each element so that it looks like a Revit model: when I select any element For example WALL, its properties such as length and volume etc are not shown and i understand because its not Revit Model. But is there any method I could do it so that when i select any element , its properties are shown. When i use Realistic view or export it to Navisworks (For viewing purpose), it all looks in same brown color which is annoying. Any tips would be appreciated.
In short my primary goal is to make it as Revit model with wall properteis and all that. But if not possible then 2nd goal is to use this Model for viewing purpose but in Realistic view or Navisworks it looks all same color.
PS: I tried alot searching and watched some vedios but could not get help and after that I posted it here.
Unbenannt.PNGRealistic ViewRealistic View
1 ANTWORT 1
Nachricht 2 von 2
alan_eu
als Antwort auf: shershahbacha9
Go to your Visibility Graphics (VG), Imported categories and apply materials directly on each layers you want :leicht_lächelndes_Gesicht:
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
