Working in both Revit LT and Revit
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
303 Aufrufe, 2 Antworten
I'm very new to Revit and just wondering if a Central Model was created in Revit 2018, can I use Revit LT 2018 to open it and work on a Local Model?  Assuming that the Central Model has only architectural and simple structural elements only.  Thank you!
2 ANTWORTEN 2
Nachricht 2 von 3
DarrenP
als Antwort auf: Anonymous
there is a whole section in the help in Revit about this:
Interoperability between Revit LT and Autodesk Revit
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-89BACB84-7B3F-44E3-A4A9-73507FAF23E3
Especially if your using a workshared file:
About Updating Workshared Projects in Revit LT
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-83A81C21-8588-48BA-8EE3-6F10A7F5021B
DarrenP
Nachricht 3 von 3
als Antwort auf: DarrenP
Thank you so much!
