work plane based family
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
gkwas
1577 Aufrufe, 5 Antworten
I am having trouble attaching work plane based components to walls.  Example; when I attempt to attach grab bars or mirrors to walls they only recognize the floor.
5 ANTWORTEN 5
Nachricht 2 von 6
Keith_Wilkinson
als Antwort auf: gkwas
Which family template did you use, it sounds like you may have used a Floor Based one if your components will only attach to the floor...
If you want it to attach to floors and walls you'd be best using a face based family.
If you can post a family it would be easier to tell.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Nachricht 3 von 6
gkwas
als Antwort auf: Keith_Wilkinson
They're actually taken from Seek, the grab bars are Bobrick and they are a work-plane based family and the mirrors are also Bobrick and are work-plane based.  They attached as you would expect them to after initially loading them into the project but now they will only attach to floors.
Nachricht 4 von 6
Revit_Whisperer
I don't see the Bobrick families...but I do see Bradley and they are face based families.  When you go to place them there is a placement panel on the Ribbon on the Modify tab that will allow you to switch the workplane.
Nachricht 5 von 6
Keith_Wilkinson
Being on Seek is sadly no guarantee of quality or fitness for purpose...
Follow what @Revit_Whisperer has suggested and see if that helps.
Maimonides
Nachricht 6 von 6
gkwas
Thank you!
