Wooden strcucture 2020
3 ANTWORTEN 3
Nachricht 1 von 4
383 Aufrufe, 3 Antworten
How do I build a wood-frame wall or wood floor on Revit? Are there tools to generate the structure automatically from a surface by defining parameters (distance between elements, etc.)?
3 ANTWORTEN 3
Nachricht 2 von 4
L.Maas
als Antwort auf: Anonymous
Normally you will use a variety of tolls to get what you want. The tools you might be looking at are
-The array tool(modify tab),  to place multiples of the same element at a certain distance form each other.
-The beam system tool (on the structure tab).
-Your own families where you build in certain behaviours.
-Some other tools that might be helpful like trusses (structure tab)
-Also curtain walls can help.
-You also might (mis)use some other tools like railings
Later you could look for certain third party apps or use something like Dynamo to partially automate the process.
You might check out some of the YouTube tutorials from the Balkan Architect how you can use some of these tools. He has several videos on creating wooden structures
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 4
constantin.stroescu
you can do it by using either Revit tools or external applications under Revit.
If using only basic Revit functions, you can do :
  • Wood Frame Wall by using Curtain Wall for 3d ,as shown in my screencast ( or only 2d , also shown in the screencast)
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/5fc...
  • for the Floor Structure , you can use Beam System
Constantin Stroescu
Nachricht 4 von 4
Are you using Revit to produce Framing Plans?
https://strucsoftsolutions.com/mwf-pro-wood/
