I will soon be doing a shingle style house where the wall flares at the base. In preparation for this project I am trying to create the base flare. I have done that using a sweep. However, when I "paint" the flare with the wood shakes - the shakes are placed upside down. I found a post from 2006 with the same issue- but the solution given doesn't work- frustrated me for a while until I looked at the zip file that was attached to the post -they used a generic 8" wall where the structure was the wood shakes - so the shakes were shown on both the exterior & interior faces of the wall.
I however need to use the Basic Wall- Exterior-wood shingle on wood stud -as I need a drywall finish on the interior. I will be working this project in Revit 2015.
Does anyone have a solution for getting the wood shakes in the correct orientation (not upside down)? Also I am not able to align the shakes on my sweep to the shakes on the wall above - and I get a line defining where the sweep joins the wall.
Any assistance I can get with this is greatly appreciated. Thanks
