wood curved beam - variabile section, editing endings of beam
4 ANTWORTEN 4
Nachricht 1 von 5
majo6541
402 Aufrufe, 4 Antworten
I have two easy question. First. Is there any way how to edit or make curved beam with variabile section/height ?
The point is, beam have big moment forces at specific place, and beam should change his height at this place.
Bellow you can see my beam.
Second. I did make beam by 3D snapping by pick line on the curved mass. But end of beam has small radius and beam endings looks not good. How can I edit beams endings?
Thank you.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: majo6541
Model it as an in place model extrusion is one approach.  Model it as a wall and edit profile is another.
Nachricht 3 von 5
You mean like this Beam?
Do it with the Spline tool.
...regarding first question: do you mean a concentric as opposed to not concentric?  You can toggle between both.  See Options Bar.
Nachricht 4 von 5
MostafaElashmawy
You need to make a new structural framing families that will be made of two or more blend sweeps
Mostafa Elashmawy
Nachricht 5 von 5
RDAOU
@majo6541
Create form using a parametric profile (repeated on a divided path) … Given the moment and the desired base you should be able to compute/derive the height of the profiles at each point
