Wiring
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
687 Aufrufe, 6 Antworten
Wiring
Anyone one can help me how to make a layer or line like autocad or how to make a electrical ciruit with different wire color at a time without selecting individual wire then by going in to override graphic view and changing the color because i want to make a specific layers in which i can make a circuit with different color.. any fast or direct way to do this..?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Fairly simple.  Duplicate you wire type to make a new type for each color you need.  Go to View visibility settings, Filter tab, and create a filter for each type.  See attached screenshot.
Nachricht 3 von 7
als Antwort auf: ToanDN
Hi Dear,
i have done this by making filters as you have mentioned in the screenshot and my all circuit wires are converted into blue color but i donot want this i just require specific circuit of my own choice with different color, kindly tell me how to implement these filters with your own choice.
Nachricht 4 von 7
Assign them with different wiring types. It sounds like you have everything on a blue type.
Nachricht 5 von 7
Dear Sir,
If you dont mind then kindly tell me how to assign different wiring type because its my start at revit.
Nachricht 6 von 7
- Select a wiring, Edit Type from Properties window
- Duplicate and give a new name easier for you to identify later
- Repeat for all the different types you need
Nachricht 7 von 7
Yeah! It's write, "Assign them with different wiring types. It sounds like you have everything on a blue type".
