Wireframe when exported as dwg
1 ANTWORT 1
Nachricht 1 von 2
mm2445
272 Aufrufe, 1 Antwort
When I export my views from Revit as DWGs and open them on Illustrator they keep showing wireframe even though they were on hidden line when exporting them.
1 ANTWORT 1
Nachricht 2 von 2
lucdoucet_msdl
als Antwort auf: mm2445
 @mm2445
Are you exporting to DWG from a 3d hidden line view or a 2d hidden line view?
There would be better hidden line fidelity if you printed the hidden line views to PDF for importing in Illustrator. You can also retain layer information when you export to PDF from Revit.
-luc
