Hi all,
I want to give conditional format to window tag - Sill Height.
I want the tag show me the Sill Heigh when different than 0. I do not want to show the Sill heght when equal to 0.
Any idea?
I think you would do it with a label with visibility parameter which checks a shared parameter value if it's >0.
You can do this through a Calculated Parameter in the Tag Family which evaluates the "Sill Height" Parameter Value.
e.g.: Formula for Calculated Parameter= if(Sill Height>0, 1,2)
Let me clarify: Are you asking if a Tag's Value can be blank if the Parameter Value (Type=Length) it is reading a 0'-0". If so; NO. But, the Tag can evaluate the Sill Height in the Project via an IF Statement to return a particular Length Value for True and False.
Understoo now.
That is a pity. So I think best solution would be a visibility parameter.
create label to read it with visible parameter
As I said before I makes totally sense use visibility function.
Just wanted to know if woudl have been possible th use of IF Conditiotional (Show Not Show) to not crete 2 Types.
Maybe only using global parameters... which would defeat the purpose really, better to use 2 types then. You could run a Dynamo script which sets the tag types perhaps based on the values.
