The document said that the following 3 server OS are support Revit Server 2021
Windows Server 2019 64bit
Windows Server 2016 64bit
Windows Server 2012 R2 64bit
However Revit Server 2021 can run on Windows Server 10 64bit environment?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Are you asking if Autodesk supports Revit Server 2021 on Windows 10? OR are you asking if it runs?
And which document are you referring to???
Both, in terms of support and run.
Technically, Microsoft® Windows Server® 10 64-bit is not on the list.
Revit Server 2021
| Operating System |
So I'd like to verify if Revit Server 2021 won't work under Windows Server® 10 environment. Or Revit Server 2021 might be installed and may work but is not supported or guaranteed to work properly.
In terms of support from Autodesk, it is not supported. It will run with no guarantees and you will need to edit the Install ini to bypass/remove OS Check (I would suggest that you download and run a trial because it is not only an OS thing)
PS: This is a user forum and I am not an Autodesk Employee. If you are seeking an official Autodesk statement, you would need to contact Support or Customer Service directly
