Windows Render Black when Image is Used in Background
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1878 Aufrufe, 5 Antworten
When doing a basic rendering, if I use the Revit "Sky: Very Few Clouds" setting my windows reflect fine.  If I change the background to an Image of a sky, then my windows black-out.  My Glass reflectivity on these is 60+, and I haven't changed the rendering settings at all between one image and the other.  Any suggestions???
-Jon
5 ANTWORTEN 5
Nachricht 2 von 6
JasonKunkel
als Antwort auf: Anonymous
I haven't tested this, but when Revit is using an image as the background, is it literally just a background... like a giant billboard behind your model?  If so, then there is nothing "in front" of the model to reflect.
Seems like a very sad workaround would be to make a huge billboard with your sky image attached, put it "behind" the camera an render...
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
Nachricht 3 von 6
als Antwort auf: JasonKunkel
Hi Jason, thanks for your response.  I am happy (albeit a little embarrassed for Revit?) to report back that your solution does in fact work.  It does however add a very tricky problem into the mix:  the location of the sun relative to this billboard.  It really limits what time of day one can shoot a perspective -- basically the sun has to have an altitude higher than 45 degrees.  Also the billboards get massive -- for the perspective I showed I needed two billboards about 5000' x 800' to catch all the windows in the project.
Anyway, thank you for your help!
-Jon
Nachricht 4 von 6
That is actually realistic if you think about it in real life.
Nachricht 5 von 6
als Antwort auf: ToanDN
Agreed Toan!  Although I would have imagined Revit to follow suit from other rendering platforms and establish a place where one can select a custom "atmosphere" other than just the standard "partly cloudly, mostly cloudy" options.  If "Background Image" was a 3D dome around the project instead of a flat piece of paper behind the rendering then the problem would be solved.
Thanks for your feedback!
-Jon
Nachricht 6 von 6
You can replace the OOTB EXR files with custom light probe images.  Make sure the images can map a hemisphere properly.  You can even convert HDR and any other image format to EXR via this online conversion tool.  Make a backup of the OOTB Presets folder before changing anything.
Below is a test.   I just picked a random free EXR on the internet so obviously it mapped all wrong.
