Hi I need the windows shutter louvers to display as trimmed out at the
arched top of the shutter. The arch of the shutter will vary and the
louvers need to adjust accordingly.
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Can you share a picture of what it is that you would like the louvers to look like or a family if you have one in progress or to use as a basis of design?
One way out would be to use a Curtain Wall with Louvers.
The other way would be to model a louver as a generic model and nest it into the window family as a nested family with a formula driven parametric array.
hi Rina Sahay i just have an issue when i try to make the arch in the louvre when i change the dimensions it wont respect my comand with the parametric array.
Down and dirty solution - don't worry about them - the ends of the louvers will be hidden in the wall.......as long as the louvers are constrained with the width and height of the opening, it should look fine.
Try this - all parameters are driven by the opening width. Should be a basis for other things.
Hi @Anonymous
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
